Thread: Renovating a Hardinge HLV-H
01-04-2009 #11
Hi Mike, Did you download the '61 wiring diagram OK (not too big in pdf form)?
Yeah, I fiddled with a number of things (I'm currently running it at 16kHz 'cos the motor's lightly loaded and it makes it silent).You might consider changing the sampling frequency as an experiment. If the motor is emitting higher frequency noises, it's often a function of mechanical resonance of the windings under load.
The 'catch flying motor' function is odd; it should have no difficulty re-syncing to a slower motor. However, it says in the spec that it auto-senses the number of poles on the motor, it's unclear if this is only happens when RUN is selected. If it only senses after RUN then that might explain why it wont sync to the motor.
After playing around with it some more today, I'm sorely tempted to add a microcontroller to the VFD's serial bus, just so I could adjust the drive parameters 'on the fly'. I'm sure it would be possible then to dispense with the speed change relays and just tell the VFD to STOP (cut the power) prior to a speed change and pick up at the correct frequency after.
I thought someone would pick-up on that :)The size of the filter capacitor on the DC bus actually has more to do with derating than the size of the diodes
I've just re-checked the Siemens' data, there no de-rating for single phase operation. although it does suggest the large power ones may need an external choke.
Interestingly, the box has terminals with access to the HV DC supply, but the manual doesn't show them. However, In an earlier model manual I downloaded, it did show them and DC brake resistor terminals. I wonder if smaller modern capacitors allow Siemens to 'over-rate' the filter for 3ph?
REBUILD: Hardinge HC rebuild
By northumbrian in forum Lathe Rebuild LogsReplies: 29Last Post: 21-02-2017, 12:07 PM -
Hardinge KL-1
By pauly45 in forum Conversion Build LogsReplies: 22Last Post: 18-10-2013, 07:31 PM -
WANTED: Hardinge hlv-h or Feeler 618
By cookie in forum Items WantedReplies: 1Last Post: 26-02-2011, 09:09 PM -
NEW MEMBER: Hardinge HLV-H Lathe
By Roger Williams in forum New Member IntroductionsReplies: 1Last Post: 25-08-2009, 01:56 PM -
Hardinge HLV-H manuals
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 10-02-2009, 12:22 AM
