Thread: my build
Page 2 of 6 FirstFirst 1234 ... LastLast
    Quote Originally Posted by Kip View Post
    What is...Be specific...is it the agricultural appearance or the use of bed frame?
    Both !
  2. Quote Originally Posted by Kip View Post
    I have no bearing location on mine.....the bearings sit against Al plate as they have no radial loads....a spacer in the middle and a belleville washer and a bolt glued in....Nice glue though ;)
    I can't visualise this... picture needed...
    or angular contact bearings (hard to get in small diameter ID).
    Look for magneto bearings, they are the smaller versions of angular contact bearings
    John S -
    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    hi guys
    thanks for input ... fixed gantry to sides today, bottom runner in , all feels pretty rigid
  5. #15
    jonm's Avatar
    going to attempt to grind down screws to 8mm then use skate bearing .. with thrust bearing either side , on evilbay thrust bearings for £1.90 each
    cant find angular contact bearings at 8mm, and magneto bearings are £6 each ....... i am after all scotsman
  6. #16
    jonm's Avatar
    never mind.. soon be time to iron last years xmas wrapping paper....
    and tippex the cards..
  7. #17
    jonm's Avatar
    cheers kip
    bag of bearings arrived from " gap bearings " today...
    will feed three 12mm bearings on to trapeziod screw fix bearings down with theseClick image for larger version.
ID:	712 drill on one end , then attack with grinder... sounds so simple....... we will see
  8. #18
    jonm's Avatar
    worked a treat took the threads of with grinder ....last few mil with a file .......
    threaded end for m8 nut
  9. Quote Originally Posted by jonm View Post
    I am impressed Jon. How did you jig the grinder to control the attack?
  10. #20
    jonm's Avatar
    irving
    done it free hand , went down with the grinder till just the very bottom of the threads were left, then set calipers to 8mm ( screw still turning with drill) and used file to take it down the rest .. checking with calipers took about a hour to do .... happy with the result
    should eliminate endfloat with thrust bearings
