Thread: One ring to rule them all?
Why don't you put the Z axis between the gantry uprights? It would put the C of G much closer to the center of the gantry bearings and you'd lose much less cutting area at the back end of the bed.
07-01-2016 #2
07-01-2016 #3
07-01-2016 #4
Yes, that's what I meant
07-01-2016 #5
Just easier to draw it hanging out the front so you can see where it is
08-01-2016 #6
I may have misread this but the two rails under the bed seem to give total support to the outside edges and none in the centre? As most of the cutting will actually tend towards the centre do you think this is a good idea?
I have never quite figured out the optimum separation but there must be one
08-01-2016 #7
Mmm as pictured the bed would be made of 100x100 square hollow section so shouldn't flex too much. However liear rail is cheap so wouldn't hurt to add one in the middle.
Just doing the numbers, using 100x100x5 shs @ 14.7kg per meter. The traveling 0 shape fixed but moving gantry design reqires 4.2m of tube per 100mm width. So for a 200mm wide traveling 0 it would weigh 120kg, heavy but just managable .
The very tall normal machine of the same size would need 15m of tube which would weigh 220kg.
08-01-2016 #8
Flex is not the real issue, right now the name of the game is minimising the overhangs -smileyface
Nitrile O-ring belt drive - suggested stretch percentage..?
By Wal in forum Linear & Rotary MotionReplies: 23Last Post: 13-05-2014, 11:49 PM -
Domestic ring main wiring
By mekanik in forum General ElectronicsReplies: 1Last Post: 15-10-2013, 05:50 PM -
Simple O-ring calculator.
By jcb121 in forum General ComputingReplies: 4Last Post: 26-07-2013, 09:00 PM -
how to measure a ring for cnc.
By crimsonred in forum Probing, Digitizing & ScaningReplies: 4Last Post: 27-09-2010, 02:47 PM -
Scrool jaw ring for hydraulic soft jaws.
By Pmac in forum Tool & Tooling TechnologyReplies: 4Last Post: 28-01-2010, 07:55 PM
