12-01-2016 #27
I was thinking slipping couplings. My ball screws don't have any flats on them so they are effectively only held by the tightness of 2 M4 screws in the coupling, where as the steppers do i think.
I would of thought if it had slipped, it would of been one side or the other rather than both Y and A.
As you say - I will mark and see what happens.. Do you think my 1500mm per min feedrate / 4mm depth cut was fairly conservative with a 6mm cutter ?
My cutter is only a straight two flute and it was screaming a little. Might be time to invest in some better cutters.
I read compression bit for plywood and cut the whole 18mm at once! Sounds like that might cause me a problem.
Martin
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
