I appreciate all of the "obvious" questions as it is easy to overlook items when troubleshooting... Yes confirmed no loose pulleys, I also have been watching the actual belts on the servos on X (hard to watch both of course) but it looks like the master is moving before the slave. I plan to swap cables to those motors and then swap drives and find where the issue follows. I can then hopefully pinpoint, cables, drive, motor being the culprit. (or still noise)
Frame grounded and I have a ground going to the gantry and to the Z axis to make sure each part is grounded in the frame.
So the separate ground would need to be bonded back to the ground ref in our house (as I believe this is code). My thinking here would be that this ground rod would give a much shorter path to earth for the Hf noise. Not sure it would make a difference or not just something I was thinking of trying.
One question I have is about running cables in the same drag chain, I had assumed that having good shielded cables that I could run all of the cables together in the same chain. Is this a No/No?
I have been looking into line filters to try to get some ordered for the servo drives and the VFD for the spindle.
17-01-2017 #2
Not good idea unless you know they are isolated. It's little things like this that can easily introduce ground loops. I would remove the Gantry and Z axis earths and check again.
Also don't Earth the PC chassis to the Star point. This can cause all sorts of strange happenings. The PC PSU will have it's own path back to earth so adding another affectively creates G-loop.!
If all is correct regards Grounding etc and with good wiring practices then shouldn't be problem. I do this all the time and don't have any issues.
However it's always good idea to keep some seperation of high power/frequency cables like VFD or Mains voltage in respect Signal wires. Esp if the wire runs are long which guess may be on your machine.Last edited by JAZZCNC; 17-01-2017 at 08:54 PM.
17-01-2017 #3
17-01-2017 #4
18-01-2017 #5
18-01-2017 #6
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
I believe that is correct to connect gantry to machine body whatever the machine, to avoid that bearing fault, it had its own name, but i forgot it...
