Thread: will this 4th axis work
I use lots of harmonic drives for my motion control rigs. I buy them second hand from ebay, but I have also bought a couple of modern brand new ones from the Harmonic Drive rep in the UK. They are very expensive new. HQ is in Germany but usually made in Japan, they own the monopoly, so the cheapo Chinese contraptions may not live up to expectations re. "zero" backlash, quality of bearings and so on. A brand new size 25 HD will usually cost a couple of thousand. I paid £1500 for each size 11 for a camera rig. They are beautifully made.
The one above from Johnattuk is a proper one with very good angular bearings. These usually come from small robotic machines that are decommissioned, a lot from S Korea, and a bit old, but perfectly usable. Some work perfectly, some have seen better days and will work, although they may be a bit bumpy at certain speeds, which you wouldn't probably notice on cnc rigs, but you do notice in motion control where perfect smoothness throughout the range is paramount.
The one you bought, Robin is too small, being size 11, with small bearings. You need at least a size 25, with size 14 being a bit marginal. Typical price for a good decent second hand size 25 with hollow shaft is around £450.
Here is a render of one of mine showing both ends
Edward
And this will give you a perspective on sizes. Size 11, size 14 and size 25
20-08-2017 #2
Lightweight ;), here's a size 50:
I had two of these sitting in my shed for 5-6 years - like Robin I found out about them and immediately decided I must have two. Then I got very sidetracked, so I sold one recently and held on to the other. I think I'm more interested now in coaxing a high torque motor into a direct drive axis, as the cost of encoders is decreasing. Seems more elegant.
One interesting point with harmonic drives is that although they don't exhibit backlash (if well made), they still do have some hysteresis. Still, beats buying a chuck driven from a stepper motor via a rubber band.Last edited by Jonathan; 20-08-2017 at 10:26 PM.
20-08-2017 #3
4th Axis Work Holding For Rectangular Work
By magicniner in forum Workshop & EquipmentReplies: 1Last Post: 20-10-2019, 03:02 AM -
B Axis indexing and easy workflow for repetitive cuts 4-axis
By deemoss in forum General DiscussionReplies: 1Last Post: 21-06-2017, 12:34 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
CNC 4th Axis at work
By Lee Roberts in forum Machine DiscussionReplies: 15Last Post: 31-07-2009, 11:35 PM
