Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    Quote Originally Posted by johnsattuk View Post
    They come in various sizes, 11 is quite a small one, do you know shaft sizes
    I think it is 6mm in, 12mm out.
  2. #32
    It could, but I've been making parts with my "rubber band" for a couple of years, how's it going with your "Doorstop" ?
    Well enough:
    https://www.youtube.com/watch?v=lVuBEEceWJ4
    http://www.mycncuk.com/threads/3341-...illing-machine
    http://www.mycncuk.com/threads/11220...-as-a-4th-Axis
    Unfortunately I ran the stepper motor on the rotary table into my milling machine column (wasn't looking) last year and bent the worm gear, so I do have another doorstop! I'm now wondering if these are better than the price suggests:
    http://www.ebay.co.uk/itm/Precision-...sAAOSwZ4dZHZkC
    The problem with the direct belt drive method is the stiffness of the belt is quite poor compared to a harmonic or worm drive. Of course, it can be useful but that depends somewhat on the diameter of the material, your accuracy requirement and other factors. If the rotary table above is any good - i.e. "most" of the backlash can be adjusted out, then that plus a 1Nm stepper motor seems like an attractive option.
  3. #33
    Surely you'll be using Anti-Backlash gears from HPC Gears as it would be a strange choice to add backlash in the primary drive (regardless of how small an error this would introduce) of a system designed specifically to avoid backlash?
    Wow, it almost designs itself.
  4. #34
    Robin if it's like mine in size 11, then it's probably 6mm in, 10mm out.
    And Jonathan, I also have a size 50 monster that I use on a crane rig, weighs a bit that one:)
    Edward
  5. #35
    That's extremely fortuitous then ;-)
  6. #36
    I just took that harmonic drive apart, one screw head decided to snap off, one had to be drilled off.
    Much as expected, only remarkable thing is how fine the gear pitch is.
    These gears are about 28mm diameter...
ID:	22685Click image for larger version.
  7. #37
    Not just the fine pitch but also the fact that they are flexible to mesh and I am not totally sure about the inner workings, but I think they have one more tooth than the gears they mesh with, or vice versa. Incredible concept and I guess very difficult to machine such precision.
    Edward
  8. #38
    Quote Originally Posted by Edward View Post
    Edward
    Need 2 teeth difference and because of the fine pitch, need a bit of care when reasemmbling as it is easy to be one tooth out, do not force.
  9. #39
    I have to get those headless screws out before I can reassemble.
    M2.5 and darned close to the bendy cog. I don't have anything suitable to grab them with.
    Any ideas?
  10. #40
    Have you tried two or three nuts locked together perhaps with heavy duty locktite retainer as well
  1. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  2. B Axis indexing and easy workflow for repetitive cuts 4-axis
    By deemoss in forum General Discussion
    Last Post: 21-06-2017, 12:34 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. CNC 4th Axis at work
    By Lee Roberts in forum Machine Discussion
    Last Post: 31-07-2009, 11:35 PM
