Thread: New start
    What do you mean when say "When I paired them again" .? The software should be taking care of the homing seamlessly in the background and you shouldn't have to be doing anything.!
    Well.. I messed up a "home x" session with an e -stop :D
    After that uccnc said slave a axis to x axis but only x motor moved.
    So I chose slave none, saved, then slaved a axis again.
    Now they work while running programs and jogging but "home x" does not work as it should..
    My bad but how do I fix it? ;)
    Ok well if changing the settings isn't working then I'd suggest you re-install UCCNC. Maybe got a corrupted file or plug-in.?
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
