Thread: Rotating Ballnut - design ideas
01-12-2019 #2
What's the thinking behind the shortest possible nut please?
The concentricity is an obvious thing and might rule out some of the cheaper offerings if my experience on the machine I've just completed is anything to go by. Having set everything up and got it working smoothly I thought I'd spin one ballnut through 180deg to get better access to the lube nipple. Major fail, that side of the axis got really stiff, it turned out that the casing/flange of the ballnut was something like 1 or 2 degrees out of alignment with the axis of the screw.
01-12-2019 #3
access/interference and balance/inertia mostly, it's no big deal and depends on the design to some degree but shorter is better in my experience.
It's not always the case obvious to everyone that's why I mentioned it. However most ball-nuts, even the cheap ones, have a machined reference surface on the outer body which you can chuck upon and skim flange if needed. Thou I've not had any issues if honest.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
