Thread: Rotating Ballnut - design ideas
01-12-2019 #11
What's the thinking behind the shortest possible nut please?
The concentricity is an obvious thing and might rule out some of the cheaper offerings if my experience on the machine I've just completed is anything to go by. Having set everything up and got it working smoothly I thought I'd spin one ballnut through 180deg to get better access to the lube nipple. Major fail, that side of the axis got really stiff, it turned out that the casing/flange of the ballnut was something like 1 or 2 degrees out of alignment with the axis of the screw.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
