    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    The main reason I ended up with my design, was it was the best way I could find to fit everything into the available space, plus I was aiming for a pretty large ratio, so pulley size wasn't really an issue. Everything was made from hot rolled steel, due to it having to carry the full weight of the knee.
    That was my 3rd revision of the design. Prior ones used two single row angular contact bearings, but they were too tall to fit in the available space.
    Once I get the Conect lathe up and running, and get the Triumph manouvered into place, I'm hoping to get back to the milling machine.
    If you want the actual solidworks files, PM me your email, and I'll send them over.
    I see, so out of the designs I've posted so far which do you think is the best option? Space is no problem at all for me.
    I'm just redrawing the latest one to use a 40mm bore angular contact bearing since that means I can bolt a sort of collar on to the end of the shaft so that I don't need to do any thread cutting.
  1. Rotating Ball nut
    By drumsticksplinter in forum Lead Screws, Nuts & Supports
    Last Post: 12-05-2020, 08:01 PM
  2. Replies: 15
  3. Rotating Ballnut Design MK3
    By Jonathan in forum Linear & Rotary Assemblies
    Last Post: 15-12-2013, 01:35 PM
  4. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
