Thread: Engraving issues
Created DXF in solidworks THEN MOVED OVER TO V CARVE
27-02-2016 #2
Not used V-Carve so not sure of the options. Check to see if the arc are made up of straight segments or if they are real curves. It they are segments, then you there may be an option to smooth the curve. This replaces the straight lines with curves that make the program run better.
Failing that it may be mechanical.
Best of luckhttps://emvioeng.com
50w laser - PSU issues?
By calida in forum Laser Machines & BuildingReplies: 1Last Post: 09-02-2016, 04:25 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Calibration issues, advice needed
By Kernow Jim in forum Motor Drivers & ControllersReplies: 16Last Post: 23-01-2014, 07:18 PM -
Page layout issues...
By irving2008 in forum General DiscussionReplies: 3Last Post: 09-08-2012, 08:10 PM -
Cable + Connector issues
By tom3d in forum General ElectronicsReplies: 0Last Post: 09-01-2012, 07:56 PM
